LabWindows/CVI
error while loading debugging information... What can I do?
I have now very often (but not all the time) the problem that I get the following error while launching the debugging:
An error occured while loading debugging information
for ´h: ....\Sequencer_dbg.exe´. You will be unable to debug this DLL/EXE.
If this DLL/EXE was built with an earlier version of Labwindows/CVI you might have to rebuild it using this version.
Would you like to terminate execution?
          YES                  NO
Then I deleted the fulll build directory and .cdb and _dbg.exe and build the program again but this error is back.
is there any solution without uninstalling/reinstalling CVI?
Thanks in advance,
Pierre-Francois.
(3,511 Views)
were you able to compile and execute your program after deleting the binaries ?
(3,489 Views)
Thank you to take time about this.
Yes I was able to compile again (sequenceur_dbg.exe successfully created), but I had then the same error that I could not debug my application because of a software version problem...
Pierre-Francois.
(3,487 Views)
