LabWindows/CVI
error
ok  my program dont wont to end , after the comport is not open, it continues and keep running the for completely
 the program suppose to shut down after the first error
can some one assist me?
(4,841 Views)
yes, that's true it does not end, i can see it only by reading the code.
and no, it is not supposed to end after the first error...
you wrote:
     status_check = OpenComConfig (physical_port, "COM10", baudrate,
                                   parity, databits, stopbits, inputq, outputq);
     switch_errors();
     for(counter=0;counter<3;counter++)
please, place a breakpoint into your switch_errors() function, then use the "step" function until the end of the software to see what is happening.
it seems you misunderstood the meaning of the return keyword (once again, i will point you toward a good programming course...). the return keyword makes the program exit the current function, in your case it exits switch_errors(), but the program continues to execute where the function was called, in your case it executes the for loop just after the switch_errors() call.
(by the way, the return keyword has the same meaning in C++... if you see what i mean...)
(4,832 Views)
now that i think about it, exit(0); will work.  it works.
i always new that return 0; mean the program ended successfully
(4,823 Views)
This discussion started in another thread: I think it is better to maintain only one discussion open on this subject.
Message Edited by Roberto Bozzolo on 10-04-2009 11:11 PM
(4,815 Views)
