LabWindows/CVI
event for menu closing?
Is there a way I can detect when a user closes a menu or menu popup?  I would like to shut down other timers in a single-threaded app when the user opens a menu.  But then I need to know when to restart all the timers.
(4,958 Views)
Have you considered creating a variable and updating it in the event callback functions for these buttons, and then using this variable to reset the timers?
(4,934 Views)
Thanks for the thoughts.  But these are for menus, not buttons.  But I think I see your thought process.  The trouble is, a user has the option of aborting a menu without actually doing a COMMIT of any one menu item.  There doesn't seem to be an event types that account for when a menu is closed.
(4,898 Views)
If you happen to use Runpopupmenu,  the return value of the function is 0 if no menu item was selected
(4,893 Views)
Hmm, that's tempting.  I do use Runpopupmenu, but not exclusively.  So unfortunately, it would be only a half-solution.
What I'm really trying to do here is to speed up my GUI during operation.  I really just need to fully commit one of these days and embrace multi-threading in my application.   🙂
(4,873 Views)
For the long term you might want to support and/or modify the suggestion of having a suitable mouse cursor event
(4,866 Views)
