LabWindows/CVI
examples using CVI 5.5 and SDK
does anybody know where can be found CVI code samples with SDK calls as
CreateDevice(...),
EnumDevices(...), SetDataFormat(...), etc.?
I'm trying to use SDK to drive a joystick in a CVI application and I'm
getting errors in linking and execution phases.
Any help is very welcome.
Thank you,
Sergio
(3,404 Views)
Hello
Since this is a Microsoft SDK, you're best bet would be the MSDN for resources.
You can also check out the newsgroups for such errors. Perhaps some other directx programmers might have had the same problems you're having.
Bilal Durrani
NI
Bilal Durrani
NI
(3,404 Views)
