LabWindows/CVI
executable not working - CVI 5.0.1
I have created a stand-alone CVI application that
worked fine in CVI 5.0 but when migrated and
rebuilt in CVI 5.0.1, it will not launch
correctly. It exits with a code of -1. Has
anyone else had this problem? Any suggestions?
(I've tried increasing the stacksize already and
it does no good)
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(6,616 Views)
In article <7ldrph$ns3$1@nnrp1.deja.com>,
> it does no good)
Does it run in the CVI 5.0.1 environment (not as a standalone
executable)?
(6,616 Views)
In article <7lec9j$uhr$1@nnrp1.deja.com>,
> > it does no good)
> executable)?
Yes, it does work in CVI 5.0.1 ( not as a standalone )
(6,616 Views)
In article <7lgiq3$nv3$1@nnrp1.deja.com>,
application that
suggestions?
already and
> > > it does no good)
as a standal
one
> > executable)?
standalone )
If you have a variable declared globally in one
module which is explicitly initialized where it
is declared then later change that variable in
that same module and then reference it via extern
in another module it will generally ONLY show the
initial value. This is ONLY true when running a
standalone executable! If you have something
dependent on proper behavior then this could be
the problem. printf debugging found this one for
me.
module1.c
int a = 5;
a = 7;
end of module1.c
module2.c
extern int a;
// whats the value of a even after
// the a=7 has executed in module1.c??
// In a standalone .exe it will probably
// still be 5!!!
end of module2.c
(6,615 Views)
