LabWindows/CVI
failed to connect DDE server on windows 7
hello guys,
A fatal error is popping up while running the code in LabVIEW CVI which is unable to launch DDE server
Is there any way out to fix this
Thanks in advance
(2,771 Views)
Hello akshay321,
did you happen to read my previous reply? Please add more details and post your code!
Additionally:
@akshay321
Are you using LabVIEW of LabWindows/CVI? They are really two different programming environments (graphical programming the former, text-based programming the latter) and I see you have posted in both boards, so please confirm which one you are developing you application with.
(2,751 Views)
Its LabWindows CVI not Labview
(2,565 Views)
Ok, good to know.
But still a lot of information is missing to begin trying to help you: which function is causing the error, which code you are using, relevant infos on configuration of the system(s) involved, error code or better a screenshot of the error message...
(2,553 Views)
