LabWindows/CVI
fatal run time error: unknown source position
If it helps at all, I believe my error was caused by a thread that was not being closed properly prior to exiting the program. Once I closed all threads properly prior to allowing an Exit, all was well.
Message 31 of 42
(4,210 Views)
I'm fighting with a similar issue.
I am getting a fatal run-time error while running a DLL either in debug or release mode. I get the following  error when my program is exiting:
Unknown source position, thread ID 0x00000554: the program has caused a "general protection" fault at 001B:00C7CABA
I'm using CVI 8.0.1 / labview 8.2 on windows XP.
This issue happens on another PC using windows 2000.
I've tried Other Dll projects: they're are not affected by this RT error but I do not see significant difference with the actual DLL project.
I (re)create a fresh project from scratch: same RT error occurs.
Anyone have suggestions on a solution ??
Message 32 of 42
(3,974 Views)
For me it looks like it happens in version 8 only, but not quite sure
It might help to update to version 9.0.1
Hi frado
Message 33 of 42
(3,974 Views)
Thanks Andy,
all my customers are using CVI 8.0.1, It is not comfortable for me to switch to CVI 9.
As I'm not facing this issue with others DLL projects, I believe there is a solution using CVI 8.0.1.
Message 34 of 42
(3,968 Views)
hi,
I have the error message : Fatal RUN-TIME-ERROR Unknown source position, thread id 0x00000C4C: the program has caused a 'General Protection' fault at 0x686DACBF
and my code is :
int  CVICALLBACK datasizemessage(int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
    int dlc,id;
    int id_button,content;
    switch(event)
        case EVENT_COMMIT:
            GetCtrlVal(panel, auto_panel_content_button, &content);
            if(content!=0)
                SetCtrlAttribute(panel, auto_panel_data_size_message, ATTR_DIMMED, 0);
                GetCtrlVal(panel, auto_panel_data_size_message, &dlc);
            else
                SetCtrlAttribute(panel,auto_panel_data_size_message, ATTR_DIMMED, 1);
            break;
    return 0;
And is appear that when I comment the second GetCtrlVal the problem does not arrive.
The auto_panel_content_button is a checked button and auto_panel_data_size_message is Numeric.
Thank you for your help and sorry for my English
Message 35 of 42
(3,111 Views)
May I ask what type of numeric you are using?  By default, a numeric control will be a double data type.  In your code, where you call "GetCtrlVal(panel, auto_panel_data_size_message, &dlc)", you are reading the value of that control into an int, which may explain why the error disappears when you comment out that line of code.  Try changing your "dlc" variable to a double type, or change the numeric control to an integer type, and see if that resolves your problem.
Shelby S
Message 36 of 42
(3,082 Views)
I just now ran into this error.
I'm running CVI 8.5.1 on XP Pro.
It's related to a system() function call where I 'm doing a ping command string.
Debug mode doesn't see this problem.
It happened the first time I ran in release mode.
Twice it occurred at the first instance that the ping is performed.
Although running release mode, I had the IDE open.
Minimizing the IDE as well as adding a ProcessSystemEvents() statement after the system() function seemed to relieve this.
What does this error actually mean?
Advise ...
Message 37 of 42
(2,962 Views)
Are you calling the ping command in a callback? Is this a console application or does it use a user interface? Are you sure you must minimize the CVI IDE in order for SystemProcessEvents to fix this problem? Or will the command alone fix it?
Check out the documentation on ProcessSystemEvents. It gives us some clues to what could be going on.
Message 38 of 42
(2,940 Views)
I didn't go back to check/verify if the IDE being open was a factor.
I'll see if I can do that ..
- Jeff
Partial Code from CVI
char  PingCommandString [256]  = "";
char  PingString        [256]  = "cmd /c ping -n 8 -w 1000 %s > \"%s\"";
// 8 pings with 1000ms timeout with output sent to file
// Send the Ping Command
sprintf( PingCommandString, PingString,"192.168.1.2", PingFileName );
sprintf(OperatorMessage, "<<< Executing system( %s ) >>>", PingCommandString);
PrintToTextbox (OPERATOR_TEXTBOX, OperatorMessage);
// The FATAL ERROR GPF occurred sometime after here and ReadFile error trap below
// because the command interpreter window was open.
Reply = system( PingCommandString );
ProcessSystemEvents(); // Added
if (Reply<0) {  .. error trap code .. }
// Open the Ping File and get the Ping test Result String
OperatorDelay(1.0); // Added - This includes ProcessSystemEvents()
PingFileHandle = OpenFile ( PingFileName, VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII );
if ( PingFileHandle < 0 ) { .. error trap code .. }
Reply = ReadFile  ( PingFileHandle, FileContentsString, 9990 );
Message 39 of 42
(2,925 Views)
What is the exact error message you see? Is it the same as the one frenchstudent saw?
Message 40 of 42
(2,904 Views)
