LabWindows/CVI
faulting module cvirte.dll, version 8.1.0.271
We have an application using LWCVI 8.1.1 and Teststand 2.0.
We have used this application for about 2 years with no problems, but in the last few week, on new pc, we have a problem.
The program craches with the message " faulting module cvirte.dll, version 8.1.0.271".
We investigated this probem, and found out, that it has someting to do with a popup window.
First we install a popup with :
MsgBoxHandle = LoadPanelEx (0, BOX_UIR, MSGBOX, __CVIUserHInst);
InstallPopup (MsgBoxHandle);
And later we remove the popup with :
RemovePopup (0);
DiscardPanel (MsgBoxHandle);
 In one of these functions, an error
The errormessage is :
Event Type:       Error
Event Source:    Application Error
Event Category: None
Event ID:           1000
Date:                12-11-2008
Time:                15:33:02
User:                N/A
Computer:         NVC1221
Description:
Faulting application tmui.exe, version 1.0.1.1, faulting module cvirte.dll, version 8.1.0.271, fault address 0x0018beda.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 46 61 69 6c   ion Fail
0010: 75 72 65 20 20 74 6d 75   ure  tmu
0018: 69 2e 65 78 65 20 31 2e   i.exe 1.
0020: 30 2e 31 2e 31 20 69 6e   0.1.1 in
0028: 20 63 76 69 72 74 65 2e    cvirte.
0030: 64 6c 6c 20 38 2e 31 2e   dll 8.1.
0038: 30 2e 32 37 31 20 61 74   0.271 at
0040: 20 6f 66 66 73 65 74 20    offset
0048: 30 30 31 38 62 65 64 61   0018beda
0050: 0d 0a                     ..
Please help.
Thanks in advance
With kind regards
Tonnie
(3,211 Views)
Dear Tonnie,
This could indicate a driver problem. Have you installed the same driver version on the new PC? Maybe it is usefull to create a list of all the software installed on both PC's (Operating system, service pack, NI Development software, NI driver software (all with versions)) to define where the problem could be.
Peter S
(3,194 Views)
