LabWindows/CVI
feature request: support for #pragma comment( lib, "..." ) in CVI
this pragma instruct the compiler to link the specified library with the project. this construct is very useful for distributing libraries or source code: add this to your header, and the user of your library does not have to include the .lib file into his project. it also avoids clobbering the project file with all external libraries, which generally are only needed by one or 2 source files. this will also add some portability.
at this moment, CVI 8.5 seems to ignore the pragma: it does not generate a warning nor an error, but the sopecified library is not linked with the project.
(4,127 Views)
Accepted by topic author dummy_decoy
Hi
Please post product suggestions through our product suggestion center:
http://digital.ni.com/applications/psc.nsf/default?OpenForm&temp1=&node=
This will make sure your request goes straight to the right persons 😉
Best Regards
Michiel
NI Belgium
(4,057 Views)
suggestion filed.
thank you for pointing to the right URL for product suggestions, i do never remember where it is.
(4,045 Views)
Great! 😉
The most easy way to find the link is to just go to ni.com and click the 'contact NI' link on the right top.
Best Regards
Michiel
NI Belgium
(4,026 Views)
