LabWindows/CVI
fft
Hello.
I am a new user to cvi and i want to undestand how to do FFT .
I want to generate sinewave and preform FFT on it and than Plot it but i am geting very strange results not as i expected iwas sure  i will get same plot as when  i am at my lab connecting sine wave to spectrum .
This is my code  .
Thx for help.
#include <analysis.h>
#include <cvirte.h>
#include <userint.h>
#include "Furie.h"
static double sine[512];
static double IM[512];
static double wave[1024];
static double phase=0;
#define NB_PTS 512
#define AMPLITUDE 2.282
#define FREQ 10.0/NB_PTS
static double SignalArray[NB_PTS];
static int panelHandle;
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "Furie.uir", PANEL)) < 0)
return -1;
DisplayPanel (panelHandle);
RunUserInterface ();
DiscardPanel (panelHandle);
return 0;
int CVICALLBACK quit (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
QuitUserInterface (0);
break;
return 0;
int CVICALLBACK create (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
SineWave (512, 1.0, FREQ, &phase, sine);
PlotWaveform (panel, PANEL_SourceWave, sine, NB_PTS, VAL_DOUBLE, 1.0, 0.0, 0.0, 1,VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_GREEN);
ReFFT(sine, IM, 512);
PlotWaveform (panel, PANEL_SourceWave, sine, NB_PTS, VAL_DOUBLE, 1.0, 0.0, 0.0, 1,VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
break;
return 0;
(4,342 Views)
I haven't run your code, but I think you want the 'spectrum' function which provides the power spectrum. You should also set proper horizontal scales if you want your graphs to make sense.
(4,323 Views)
Accepted by topic author iliya24
Hello iliya24,
Is there a reason why you are using the ReFFT function? According to the help file (http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvirefft/), this function is obsolete. You can use FFTEx (http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvifftex/) or FFT (http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvifft/). In this help, there is some helpful example code that you can use as a test in your program. You also may be able to see the FFT more easily if you do not plot the sine wave.
Jason D
(4,309 Views)
thx
(4,306 Views)
