LabWindows/CVI
file selection popup
hi i am using file selection popup to get a file selected..
but i want the directory of the file selected..
is there anyway to retrieve the directory of the file selected ....
(4,039 Views)
SplitPath function should be what you need for it.
(4,036 Views)
thanks robert..but i am working in VC++ using LCVI as Front end/user interface..
so wat can i do if i want to split directory from path in VC++ ..
(4,032 Views)
You could always try something based on the ANSI function strrchr (). Perhaps:
    char *ptr;
    if (ptr == strrchr (copy_of_filename, '\\'))    // Find the last directory separator
        *ptr = 0;                                   // Terminate the string there, if it exists
This will alter copy_of_filename to become just the directory part.
JR
(4,017 Views)
I don't see any reason why you can't use the CVI function, you are already importing CVI stuff for the UI, so why not a few more functions if you need them?
The first virtue of the programmer is laziness, reuse code that is already written instead of writing your own.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,999 Views)
