LabWindows/CVI
filetoarray
I was wondering if the filetoArray function separate the columns in the file. I want to open a .dat file that has 2 columns which will be my x and y to plot.  Can i use filetoArray with this?
(5,627 Views)
FileToArray can split the content of a file into several groups: playing with the options of FileToArray command you can accomodate the function so that it can read several file types.
You can look at the attached example: it's the standard arrayfile example that ships with CVI (it's located into sample\fileio folder) that I have modified to treat a two-dimensional array both in writing and reading.
(5,612 Views)
Thank you for your response.  However, it does not seem to work if the file I am opening is in not written in CVI.  When I try to copy the 1d it said that it was not initialized.  Basically, I need to open a file (not necessarily from CVI) put it into an array and then plot it.  I really appreciate this.
(5,579 Views)
Hi Jemellie,
Can you tell us what line of code is the error coming from? What's the exact text of the error?
Mark E.
(5,535 Views)
The problem is when I plot it, its just a straight horizontal line at zero, when clearly its not supposed to be that way.
  if (FileSelectPopup ("", "*.txt", "*.txt", "Name of File to Read",
                  VAL_OK_BUTTON, 0, 0, 1, 0, file_name) > 0){
                GetCtrlVal (panelHandle, PANEL_InputType, &fileType);
                FileToArray (file_name, array, VAL_DOUBLE, COUNT, 1,
                             VAL_GROUPS_TOGETHER, VAL_GROUPS_AS_COLUMNS, fileType);
                Copy1D (array, COUNT, xonea);
                Copy1D (array + COUNT, COUNT, yonea);
                /*for(i=1; i=COUNT; i++){
                    xonea[i] = xoneb[i]/10000;
                    yoneb[i] = yoneb[i]/10000;
                DeleteGraphPlot (panelHandle, PANEL_GRAPH_3, -1, 1);
                PlotXY (panelHandle, PANEL_GRAPH_3, xonea, yonea, COUNT, VAL_DOUBLE, VAL_DOUBLE,
                       VAL_THIN_LINE, VAL_NO_POINT, VAL_SOLID, 1,VAL_BLUE);
Thank You!
Message Edited by Jemellie on 06-24-2009 10:41 AM
(5,496 Views)
Hi Jemellie,
is the file you are trying to read an ASCII file or a binary file? In the first case I never had problems with FileToArray even with files produced by other programs: you may have to fiddle a little with command options but you are very likely to succeed. If you can post here a small sample of this file, we may try to help you in a more concrete way.
In case your file is a binary one, you may find problems if the other application does not stores data as CVI expects. Being this the case, can you detail a little how your file is created (type of data stored in it, organization of data within the file...)? Again, a small file sample together with relevant informations about it can help us in driving you to the correct way.
(5,492 Views)
