LabWindows/CVI
find the most common number and display on CVI program
Hi NI,
Can advice how to do the below task using CVI software
1) Read 10 data(range only 1 to 10) (throught serial com-bluetooth drvice)
2) Check the 10 data receive and get the most common number number occur and step 3
3) Display on the CVI display the most common number.
SB
(3,880 Views)
A very general guidance on how to address this problem could be:
  1. Use RS232 library or VISA to read from the device. Accumulate measures in a array
  2. Sort the array and count values. If numbers are floating point you will need to design a rule to decide how close numbers can be to be counted in the same group
  3. ... (I hope you don't need help on this! Smiley Wink )
(3,877 Views)
Any sample CVI sort arry doc for beginner to share?
(3,848 Views)
here is one
(3,845 Views)
