LabWindows/CVI
float to IEEE754: accuracy problem
I have a problem with this operation.
Example it's simple and gives correct results until I try with *.0 values, like 30.0
The output string is in this case the string for 29.999999
How can I avoid this?
(3,141 Views)
LabVIEW related question: see discussion here
(3,113 Views)
