LabWindows/CVI
fopen and timeout-poblem
hi,
in a "c"-source the programmer used the ANSII - fopen() to build streams to serial ports RS232. Does anybody know how to set the timeout of the read-functions e.g. the fgetc() - function ? the system now waits about 5 sec if the buffer of the port is empty.
best regards
Simon
(4,049 Views)
The RS-232 library has functions that make com easier than using fopen and fgetc.  It has the SetComTime function to set the timeout.
SetComTime (int COMPort, double timeoutSeconds);
The default timeout is 5 seconds.
(4,040 Views)
ok, but the sources I got were written by using fopen() etc. do you know how to set the timeout there ?
simon
(4,008 Views)
Have you tried using SetComTime?
(3,990 Views)
I haven't tested it, but CVI RS-232 library contains GetSystemComHandle function that returns the system handle to the com port used: this value should be passed to SDK SetCommTimeouts function to set appropriate timeouts for both input and output: maybe you can give a try to it.
Hope this helps
(3,961 Views)
