LabWindows/CVI
force to build nidobj
How can I force LabWindow/CVI to generate *.nidobj for all object file when i build with debug configuration?
Some .c file in my project are complied to *.niobj even when I build with debug configuration.
(3,222 Views)
Make sure you don't have the 'O' option (compile into object file) enabled for that particular C file. If you right-click on the .c file in the workspace, and you see a menu item "Disable 'O' option", means that CVI is creating the object file for the source without debugging information.
Hope this helps
Bilal Durrani
NI
(3,213 Views)
