LabWindows/CVI
formatting specifier for int64
dealing with 64 bit integers I receive the run-time error message: parameter type incompatible with format specifier.
I am using
static long long int counts = 0;
and the function FmtFile ( file_handle, %d, counts )
It appears that the formatting library does not support int64... ?
I just found the solution: use FmtFile ( file_handle, %d[b8], counts )...
Message 1 of 1
(3,134 Views)
