LabWindows/CVI
full paths in history
Is there a way of getting more than just the filename to appear in the history list for 'File Open'?
If there are numerous projects with the same name (i.e. TestExec) then you don't know which ones they are.
As a minumum, perhaps the full path could be displayed in the status bar as the mouse highlights each entry?
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(3,446 Views)
That's a good suggestion. We'll look into displaying it in the status bar.
Luis
(3,428 Views)
Alternatively one could consider tooltips...
(3,423 Views)
I think the status bar is better because it would also help people who like to navigate menus with the keyboard. Also, even if you're using the mouse, tooltips would require you to pause for a couple of seconds in order to see the tooltip.
Luis
(3,416 Views)
