LabWindows/CVI
get day
I'm using CVI 6.0 and WIN XP PRO SP2.
I need to get the day of the WEEK, I've used the MSCAL (Active X calendar) but MSCAL will not tell me if I'm monday...or any other day of the week. I took a look in the CVI library and even in the DATE/TIME library nothing will tell me the day of the WEEK. So is there a method to find out the current day of the WEEK wich is a value 1-7 ?
Thank you,
(4,961 Views)
You can use 'InternationalDate' function from the Programmer's tool box to get the information of current day.
I do not think we have direct functions in CVI to know about the information of any date.You can develop a program in LabVIEW using the Date/Time functions which do that and call the dll in CVI.
Siddu
(4,949 Views)
This should work if you have the year, month and day:
#include <time.h> // struct tm, etc are defined here
void GetDay(void)
// Set up a variable of type struct tm and a pointer to it
struct tm ts, *t=&ts;
// this will contain the calendar date in seconds
time_t ct;
// local variables
int year, month, day, weekday;
// Example: 16 December 2004
Year = 2004 - 1900; // years since 1900
Month = 11; // January = 0, February = 1, etc
Day = 16; // The first day of the month is 1 (not 0)
// Zero out the tm structure
memset (t, 0, sizeof(struct tm));
// Set the year, month and day
t->tm_year = year;
t->tm_mon = month;
t->tm_mday = day;
// Get the calendar time
ct = mktime(t);
// Convert to component parts
t = gmtime(&ct);
// Add 1 to weekday for a value of 1 to 7
weekday = t->tm_wday + 1;
// weekday contains the day of the week
// 1 = Sunday through 7 = Saturday
If you want the current day use the function DateStr().
George Hodgson
"gasma1975" <x@no.email> wrote in message news:169698@exchange.ni.com...
> Hi,<br><br>I'm using CVI 6.0 and WIN XP PRO SP2.<br><br>I need to get the
wich is a value 1-7 ?<br><br>Thank you,
(4,941 Views)
// Note that angle brackets around time.h stripped from message as invalid HTML
#include time.h //ANSI standard time/date library
int DayOfWeek() {
struct tm *newtime;
time_t long_time;
time(&long_time); // Get time as long integer.
newtime = localtime(&long_time); // Convert to local time.
dow = newtime->tm_wday; // Day Of Week - Days since Sunday 0-6
return dow;
} // End of DayOfWeek()
(4,940 Views)
Thank you! I'll keep that in mind for future posts.
George Hodgson
"TotalAJ" <x@no.email> wrote in message news:169797@exchange.ni.com...
HTML<br> <br><br>#include time.h //ANSI standard time/date
library<br><br>int DayOfWeek() {<br> struct tm *newtime;<br> time_t
long_time;<br><br> time(&long_time); // Get time as long integer.<br>
newtime = localtime(&long_time); // Convert to local time.<br> dow =
newtime->tm_wday; // Day Of Week - Days since Sunday 0-6<br> return
dow;<br>} // End of DayOfWeek()
(4,935 Views)
Yet another implementation...
double timeStamp;
int dayOfWeek = 0;
char dayString[10] = {0};
// Valid values are 0–6, where Sunday is 0
FormatDateTimeString(timeStamp, "%w", dayString, sizeof (dayString));
// convert to integer
sscanf(dayString, "%d", &dayOfWeek);
(3,572 Views)
