LabWindows/CVI
get pixel location from table cell coordinates
I have a spreadsheet that uses conditional coloring if values are in spec.  I am trying to use CVI to read the color.   I am use the following:
error = Excel_GetProperty (ExcelInteriorHandle, &ErrorInfo, Excel_InteriorColorIndex, CAVT_VARIANT, varVariant);
For all the cells using conditional color formatting it returns a 38.  On a cell that I manually set to green it returns 14.  On cells with no color set it returns -4142.  Is there some other way of determining the results from conditional coloring.  I want the client to be able to modify the rules in the spreadsheet without me having to do any changes in my program.
(2,715 Views)
Hi mjl,
That appears to be a limitation of the Excel Interior.ColorIndex property, which returns either the index of the color in the local palette or a constant called XlColorIndex that indicates either no color or automatic color.  -4142 is no color.
It looks like there is a property called Interior.Color that returns the actual RGB color value as a variant that may be more useful to you.
Michael B.
Product Support Engineer
(2,682 Views)
I tried using Excel_InteriorColor.  In my code it returns a variant of type double always with the same value, 13551615.0.  When converted to an ingteger gives 0x00CEC7FF in hex.
I'm also not sure how my post ended up here since I tried to start a new post.
(2,671 Views)
