LabWindows/CVI
get size of double array?
Are double arrays able to contain null values? Also, what is the double array equivalent to strlen( )?
Sorry for the noobish questions!
(7,707 Views)
If you mean NULL, remember that NULL is defined as ((void *)0), i.e. a pointer.
If you want to obtain the size of an array, you can use sizeof ( array ) / sizeof ( double ).
Hth,
Wolfgang
(7,703 Views)
Or more generically
sizeof(array)/sizeof(array[0]);
(7,700 Views)
My apologies, that is very helpful, but what I meant to ask is how would I query the amount of elements in a double array?
for example:
double rhoArray[]={.118,.040,.025,.014,.007,.005,.004,.003,.002,.002,.003,.005,.012,.016,.020,.023,.021,.020};
numElements = strlen(rhoArray);
(7,618 Views)
Accepted by topic author TurboMetrologist
I'm not sure what you're asking.
sizeof(array) tells you how much space the entire array takes.
sizeof(array[0]) tells you how much space one array element takes.
sizeof(array) / sizeof(array[0]) tells you how many elements are in the array.
Anything else?
(7,615 Views)
(5,341 Views)
