LabWindows/CVI
getnextfile()
is GetFristFile() works only with directory path or it can also support url like ftp://10.10.12.13/
i need to retrive filename available inside the folder reports which is under url path ftp://10.10.12.13/reports/
(4,241 Views)
I'm pretty sure it cannot directly support the FTP url syntax. If your program could map the remote drive to a local drive letter, though, then this approach would definitely work. (You could try something along the lines of: system ("net.exe use z: ...") to generate a drive mapping within your CVI program. Sorry I don't know the details of the associated syntax - I'm on the wrong PC!)
JR
(4,240 Views)
I guess the suggestion of JR is the way to go: Windows provides the possibility to map network drives to a drive name, i.e. you could map a remote drive to 'Z:'; this has to be done in Windows; subsequently, you can access this drive as any other drive using the usual syntax.
(4,234 Views)
is their any other way to read the filename available inside the ftp server. i tried mapping the ftp network drive and dont know how to proceed further also i feel its bit tough job.
or else pls give me suggestion, to copy n number of files from ftp remote server to local system.
(4,223 Views)
Another possibility is to use the function InetFTPGetDirList which returns the list of files in the current directory on the FTP server.
(4,218 Views)
but when i was trying with InetFTPGetDir i am getting System socket error, i tried with ftpclnt.cws project in that also i am getting socket error...
my setup connection is correct dont know wr the real problem.... help me in solving this........
(4,215 Views)
raj,
It's difficult for others to remember what you might have tried earlier: the current post was about using getnextfile; the answer was: you can probably use it if you manage to map your network drive.
so if this question is solved, you should mark the current thread as solved and start a new one, with an adapted, meaningful title. This makes life a tiny little bit easier 🙂
(4,209 Views)
