LabWindows/CVI
gui update for xp slower ?
a process is periodically updating a GUI.
with WinNT it works fine, with WinXP sometimes the update is delayed or not visible.
is something changed concerning the priority of GUI-update from NT to XP ?
br
cvifan1
(3,064 Views)
Don't know anything about XP (never used it) but I will suggest that you
have ProcessDrawEvents() call in your code after you update the GUI.
This way your are forcing the update to happen righ a way.
vishi
> or not visible.
> XP ?
> br
> cvifan1
(3,064 Views)
What do you mean by "A process is periodically updating a GUI"? if you have a call to RunUserInterface() and the callback take a decent amount of time updating the UI should be transparent. However Vishi's idea is the best to ensure that the UI gets properly updated.
As far as I know there were no changes to the thread priority in WinXP. However you can create your own thread and assign it a higher priority to ensure the updates, but I don't feel this should be necessary unless the CALLBACKS take a long time.
I hope this helps a bit, let me know if you have further questions.
Juan Carlos
N.I.
(3,064 Views)
