LabWindows/CVI
having problems with BUILD SAMPLE DISTRIBUTION
Hi there,
I have am going through the "Getting Started" manual and have compiled & build the program "Sample 1" successfully but when following Section "Editing the Distribution" from the manual I am having problems with building sample distribution.
Earlier it failed on the output path not accessible then i changed the path to my docs..and now it is giving the following error
*** Error: An internal tool or library returned an error. (Error code -21)
Error adding file: sample1.uir
*** End Error Report
Looking forward for a response urgently
Dhaivat
(3,042 Views)
Hi Dhaivat,
When you start section 6 of the exercise do you alter the filepath of the Settings File? if so try leaving the filepaths to their default values and just make a note of where the distribution will be created.
I found and article which may help clarify the error code you received when you changed the filepath, here is the link to it
http://digital.ni.com/public.nsf/allkb/4F6A2071241A86AA8625726D00039892?OpenDocument
Hope this helps
Steve
(3,018 Views)
Hi Steve,
Thanks mate. I have already sorted the error. I think it was unable to find the files as you mentioned and also that few files where showing 0KB next to their name. i.e. the builder couldnt recognise the path of the file..
Many thanks
Dhaivat
(3,013 Views)
