LabWindows/CVI
haw get a timer value
haw get a timer value and haw display this
(3,472 Views)
Hi viorel,
you can get you timer value by using the command below, assuming it is a timer control on the .uir
GetCtrlVal (int Panel_Handle, int Control_ID, &Value);
To set the value into a control on the .uir:
SetCtrlVal (int Panel_Handle, int Control_ID, Value);
you can also find some useful information in the Menubar>>Help>>Contents
Hope this helps.
Regards
AL
(3,470 Views)
Another way is to use Timer () function, useful if there is no timer control loaded.
Different is the case if you want to know actual clock time: in that case you can use TimeStr () function.
(3,465 Views)
