LabWindows/CVI
hide value in text ring
Hi.
I am a new user of labvew and face this problem. Can the values that text ring takes be controlled by a menu ring?
For example. Menu ring ghas to pataemters :FREQ and VOLT, and the rext ring has 4 parameters:1000khz,2000khz, 4v,5v. My idea is when a first parameters is chosen,FREQ, text ring will show only twp corrnesponding values,1000kz and 2000khz, other values that are not relivan to FRQ qil be hissen. I fell like it is possible to imåplement with prperty niode, but I donät know whta function ro choose , there are so many.
Thank you in advance.
(3,515 Views)
Hi Rom86, your question is related to LabVIEW and should be posted in the appropriate forum: this board is dedicated to LabWindows/CVI and its users.
(3,502 Views)
Hi Rom86
Roberto is right, you get better help by posting in the right forum. Don't know if you've already reposted in the LabVIEW forum or if you solved you problem, but here is quick example anyway.
Regards
David
NISW
(3,440 Views)
