How can I find prototype info for the CVIRTE.dll. While using Teststand the prototype info does not import into the calls. I need to edit the prototype info to use the CVIRTE.dll functions.
Not sure if you are still dealing with this issue, but its usually best practice to create a CVI DLL that you call from TestStand rather than call the core CVI RTE DLL itself. Was there any particular reason you were trying to call CVIRTE.dll directly from TestStand instead of creating a CVI DLL?
