LabWindows/CVI
how can I use 82350 PCI GPIB mdade by Agilent with LabWindows CVI on WIN2000
I get the evaluation LabWindows CVI and try to use it with my GPIB PCI card on Win2000, but the CVI can not located the Port of this card. So, what I need to do?
(3,107 Views)
Hi Gilson,
Can you be more explicit about how CVI "cannot locate the port of this card"? Because the card is not a National Instruments card, it will not be available in MAX and you will have to make direct calls to the Agilent drivers to do communication. I am sure that Agilent exports functions to make programming the card from C (CVI is an ANSI C enviroment) possible. Refer to the user manual for the card for more information.
Hope this helps,
Aaron K.
Application Engineer
(3,106 Views)
