LabWindows/CVI
how can i add .dll file in cvi6.0 without .h or .lib file?
dear sir:
this day i meet a question with dll,i must add a dll file to my program,this dll is support by the manufacture,only .dll and .sys file, so i use loadlibrary and GetProcAddress function,but when i debug it there is a error:Missing prototype,and then i copy .sys file to \\windows\system,the error is still have,and now what can i do,please see my pragram at attachments.
(3,182 Views)
if you know the function name and parameters,you can use Loadlibray();GetProcAddress();they are all APIs,you can refer to SDK !
good luck!
(3,182 Views)
The missing prototype was for the loadlibrary function. You need to include windows.h as the first include ( on the very top) in your test.c file. LoadLibrary and GetProcAddress are SDK functions and to be able to use any SDK functions in CVI, you almost always need the windows.h header
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,182 Views)
