LabWindows/CVI
how can i delete a key from my .ini?
I write/read .ini file through WinAPI
WritePrivateProfileString/ReadPrivateProfileString,now i want to
delete a key from .ini,how can i do?
thanks for any help?
(3,715 Views)
Hello
To manipulate ini files, you can use the functions provided in the ini toolbox for CVI. Check out the example under ..\CVI\samples\toolbox\ini.prj. It shows you how do to the various operations and it alot easier to use than the WIN API
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,715 Views)
