LabWindows/CVI
how can i do have to use vc6.0 static library in cvi8.0
Can the cvi use the static library code which produced in vc6.0. if can ,what to do? thanks.
(3,373 Views)
可以,只需要将.dll ,.lib 和 .h文件复制到工程目录下,将.h和.lib添加到工程中就可以使用了.
(3,243 Views)
simply add the .lib file generated by vc6 to your project as well as the corresponding .h file.
(3,240 Views)
