LabWindows/CVI
how do I include CAN function tree to my CVI/LabWindows application?
I just installed CAN2 driver set (V2.1.1) with LabWindows/CVI 7.0. How do I include CAN function tree and include CAN to the Libraries menu in LabWindows? I have tried installing CAN drivers after LabWindows/CVI. The option for CAN driver inclusion to CVI application is checked. I still don't see the libraries or the FP. Also tried including the libraries file to my project, but it doesn't help.
Thanks for your response.
(3,091 Views)
Hello
Make sure you have added CVI support while installing the NI-CAN driver. The libraries for CAN should get installed in the ..\CVI70\bin folder. There will be a nican.lfp and associated files there.
Also, if you go to the menu item Libraries >> Customize, make sure that the NI-CAN library box is checked.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,091 Views)
