LabWindows/CVI
how do I perform simple pixel by pixel subtraction of data in imaqbuffer (ni-imaq)
I have a need to subtract two images.  Now I know this is a function in Vision, but I want to use plain old imaq.  So, I grab two images from 2 seperate NI1405 framegrabber cards using
imgGrab (Sid, (void **)&ImaqBuffer, TRUE);
imgGrab (Sid1, (void **)&ImaqBuffer1, TRUE);
and then call a function that I wrote: absSubtractImage(imaqBuffer, imaqBuffer1):
//pixel by pixel image subtraction
//absolute value
//assuming data is laid out as follows:
//pixel 0, pixel 1, pixel 2...
//00RRGGBB, 00RRGGBB, 00RRGGBB...
int absSubtractImage(Int8 *img1, Int8 *img2)    //img1 << img2 - img1
    int i;
    unsigned int bufSize;
    //make sure that the image sizes are the same
    if(sizeof(img1) != sizeof(img2))
        return -1;
    bufSize = sizeof(img1)/sizeof(Int8);
    for(i = 0; i < bufSize; i++)
        *(img1+i) = abs(*(img2+i) - *(img1+i));
    return 0;
Problem is sizeof returns 4...; problem probably has to do with the fact that I am probably not dereferencing the pointers correctly.  Could someone please guide me?
Owais
(3,101 Views)
Please ignore the above request.  The answer to the number of elements is multiplying the ROI width x ROI length x pixel depth...
(3,089 Views)
