LabWindows/CVI
how i can get and select an Excel Worksheet by its name??
How can i get an specific worksheet, by its name.
I do the following based in another example about the workbooks:
// Get the active Worksheets
Excel_GetProperty(ExcelSheetsHandle,NULL,Excel_WorksheetsCount, CAVT_LONG,&ExcelSheetsNumber);
for (i=1;i<=ExcelSheetsNumber;i++)
Excel_WorksheetsItem (ExcelSheetsHandle, NULL, CA_VariantInt(i), &hCurrentSheet);
Excel_GetProperty (hCurrentSheet, NULL, Excel_WorksheetName,CAVT_CSTRING, WorksheetName); SetStdioWindowVisibility (1);
printf(" %s",WorksheetName);
I put an Stdio Window to see the effect of the variable that i get, but its split only garbage
How can I get the string of the Worksheet and select this wor
ksheet by its name???
I would apreciate your help !!
Eduardo Zagal
(3,445 Views)
Hello
The way the excel object model is setup, you have first get a handle to the application object.
error = Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets,
CAVT_OBJHANDLE, &ExcelSheetsHandle);
Then use the following function to get a handle to the worksheet object based on the name
CA_VariantSetCString (&sheetVariant, "Sheet2");
error = Excel_SheetsItem (ExcelSheetsHandle, NULL, sheetVariant,
&ExcelWorksheetHandle);
once you have this, you can make it active.
error = Excel_WorksheetActivate (ExcelWorksheetHandle, NULL);
Refer to the CVI Excel shipping example for more info on this, found at ..\CVI\samples\activex\excel\.
Also check out the excel activex object m
odel on how this is setup in excel. You'll be able to get information on this from the MSDN.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,445 Views)
Thanks for your help !!
It's exactly that i was looking for !!!
Regards
Eduardo
(3,445 Views)
