LabWindows/CVI
how save data to microsoft access labwindow
I want know how save data from lab window CVI  to microsoft access and how to show data from microsoft access to lab window as I am the biginer of using lab window could any tell body tell me the easy way . Thank you very much
best regard
 tankao
(3,255 Views)
Tankao,
First, you can consider using the enterprise connectivity toolkit. Alternatively, you may use the built in CVI activeX wizard to create an activeX controller and access the Microsoft Access activex server. You can do so by following the instruction in this knowledgebase article. For the descriptions of individual functions, you would need to consult with Microsoft, such as msdn.com.
Song Du
Systems Software
National Instruments R&D
(3,223 Views)
