LabWindows/CVI
how to access the result list in teststand after execution using labwindows/cvi
I am developing a user interface in labwindows/cvi that runs multiple teststand sequence files and would like to combine their reports (generated in teststand) into a single file at the end of a UUT. What is the best way to do this? At the moment, I'm trying to access the result list local variable after the execution has ended using API calls from labwindows/cvi and an end-of-execution callback event but those run-time variables do not exist anymore. How do I get a hold of the result list array at the end of an execution? I would like to grab this variable and pass it along from sequence to sequence using labwindows/cvi and not teststand itself. Is this possible? Any help would be great.
Thanks in advance,
Luis
(2,945 Views)
Hey Luis,
Check out the response to this thread at the NI TestStand board here!
(2,921 Views)
