LabWindows/CVI
how to acquire the MR triggering pulse
I write a vi that required to acquire an MR triggering pulse to start (sync with the MR scanner). The general triggering pulse from the MR is 50 microseconds; and can be extended up to 500 microseconds. I am using USB-6221 digital port to acquire this pulse. However, it doesn't seem to catch this pulse. Would it be the hardware problem? I attached my vi; maybe I did something wrong in the vi.
(3,460 Views)
you have posted your question in the LabWindows/CVI forum - you might want to post it in the LabVIEW forum instead...
(3,457 Views)
EDIT: once again my typing is too slow!
(3,453 Views)
I am sorry JR,
if I only would have known that you were typing too, I certainly would have given you the advantage...  Next time I'll have a coffee first Smiley Wink
(3,446 Views)
thank you and I will post it again in 'Discussion Forums'.
(3,440 Views)
the thread continues here
(3,435 Views)
