LabWindows/CVI
how to change menu bar font programmatically
Hi all,
I want to change the font and the font size of a menu bar programmatically. Therefore I thought I should use the following function:
<<SetMenuBarAttribute (panelMenuBarHandle, Menu_FILE, ATTR_MENU_BAR_FONT, VAL_EDITOR_META_FONT);>>
and the same for changing the size.
But I get permanent error (return value -46, the attribute passed is not valid). Changing size and font in the user interface editor and saving changes in the uir-file is no problem!
Any suggestions?
Thanks for your help.
(3,683 Views)
Forgot to inform you about the version of CVI: it's 8.0.1 on a Win2K system.
(3,669 Views)
I believe that you can only change the font for the whole menu bar, so perhaps it would be better to pass 0 as the second parameter rather than Menu_FILE.
Martin
Certified CVI Developer
(3,663 Views)
That's it - thanks Martin!
(3,657 Views)
