Unfortunately, no, this is not a settable option. If you are using CVI 6.0, then you can do it with our CWSlide ActiveX control in the CVI ActiveX container. Our ActiveX control does have the option to have the ticks and labels above or below the slider.
Best Regards,
Chris Matthews
