LabWindows/CVI
how to check if a panel is temporary available
Hallo everybody,
I have to check if a panel is available. I want to control a loop. He has to run if the panel is available and is not yet closed.
How can I check this?
Thanks.
Florian
(3,444 Views)
How about:
 GetPanelAttribute (panel, ATTR_VISIBLE, &status);
This sets status to a 1 if the panel is visible.
JR
(3,437 Views)
I saw "available" was misunderstood. I meant "exists". You could close the panel, and if it is almost close, the function didn't has to.
>>>   You can't get an information from "nothing"
(3,430 Views)
OK have you thought of using a panel callback function and working with the EVENT_CLOSE case to let your program know that the panel no longer exists?
JR
(3,427 Views)
Oh that's an idea, I didn't thought. Yes of course, this will work. Thanks
(3,424 Views)
