LabWindows/CVI
how to close the application when it crashes in labwindows
           In Labwindows 2005 TCP Server Client application, after establishing the connection from server to client , if I want to close the client application,  client application get crashes.
(4,002 Views)
Normally the communication is the opposite side: the server application register itself as a server and the client connect to it using ConnectToTCPServer (): are you doing something different?
Before closing, the client should disconnect from the server by calling DisconnectFromTCPServer (): do you call it?
Are you receving any error message in the crash? Is Run >> Break On >> Library errors menu item checked?
Can you post the relevant code?
(3,987 Views)
