LabWindows/CVI
how to compare value from database reading
Hi CVI Expert,
I want to find if serial number that i input has already been exist on database or not. I use sql toolkit. My database is MS Access.
Here the code that i tried :
hdbc = DBConnect (connectString);
if (hdbc <= 0) {ShowError(); goto Error;}
hmap = DBBeginMap(hdbc);
if (hmap<=0) {ShowError(); goto Error;}
resCode = DBMapColumnToChar (hmap, TraceSerial16, 17, uutNum, uutStat, "");
if (resCode != DB_SUCCESS) {ShowError(); goto Error;}
hstmt = DBActivateMap(hmap,"CounterTable_Control");
if (hstmt==0)  {ShowError(); goto Error;}
while ((resCode = DBFetchNext (hstmt)) == DB_SUCCESS) {
if (uutNum=="8003050013031014"){
statusSN = 1;
break;
else
statusSN = 0;
printf("Serial Number %s \n",uutNum);
if (statusSN==1){
MessagePopup("Status","OK");
resCode = DBDeactivateMap(hmap);
if ((resCode != DB_SUCCESS)) {ShowError(); goto Error;}
resCode = DBDeactivateSQL (hstmt);
resCode = DBDisconnect (hdbc);
My problem is, the comparison nevers succeed (red text). Can you help me why ?
(3,177 Views)
Comparing strings works differently. You should use strcmp(string_1, string_2)
(3,175 Views)
Yeah, as Wolfgang said, use the ANSI C string compare library function.  Look at the help for the strcmp() function.  It returns 0 if the strings match.
In ANSI C,
acutally compares the pointers to the strings, not the string content.  That's why you never saw a match.
(3,166 Views)
Thank you guys. It works well.Smiley Happy
(3,162 Views)
