LabWindows/CVI
how to connected to the Internet and change system date/time?
Hello
I want to know if my computer is currently connected to the Internet.
So I'm looking for several related functions. But I could not find it.
And I want to change the date/time on my computer. I have tried the following functions:
SetSystemDate();
SetSystemTime();
I changed it on my development PC. However, after making it as a distribution, it was not changed on the Panel PC.
The OS of the Panel PC is Windows 7 Embeded.
I want to know if there is another way to change the date and time.
Thank you.
(2,829 Views)
The SetSystemTime() should work on windows 7 embedded. It may be required to use EnableSetTime() first. Also make sure that the user has the privilege to change the computer time.
We use the following code snippet:
  if(EnableSetTime())
   // Change the computer time.
   setTime=SetSystemTime(&newTime);
   if (setTime)
    // Tell all panels that time changed
    SendMessage(HWND_BROADCAST, WM_TIMECHANGE,0,0);
    DisableSetTime();
(2,797 Views)
Hi.
Thank you for reply.
I tried the way you suggested. But I can not find the "EnableSetTime ()" function.
It is not defined anywhere.
I think user do not have the privilege to change the computer time.
I would like to know how to change the permissions on the Windows 7 Embedded OS so that the user can change the time.
Thank you very much.
(2,756 Views)
