LabWindows/CVI
how to control cursor setting programatically ?
Hi ,
How can I control cursor setting i.e if I want to programatically display On & OFF the cursor or if I want to disable and enable it programatically then what should I do plz tell me .
subrata
(3,423 Views)
Howdy embedded,
If I am understanding correctly, then you could check out the SetCursorAttribute() function and set the ATTR_CURSOR_ENABLED property. For example, to disable the cursor you could say
SetCursorAttribute (panel, PANEL_GRAPH, 1, ATTR_CURSOR_ENABLED, 0);
Hope this helps!
Best Regards,
Jonathan N.
(3,413 Views)
