LabWindows/CVI
how to create IVI-Driver usign Labwindows
I need to developed IVI-Custom class drivers for the non IVI-Instruments, how I can do that using the Labwindows (version 8.1 which has create IVI-Custom class driver option in the menu). Pls let me know.
One more question: How I can create a installer using Labwindows create IVI driver installer option for the custom IVI-driver?
Prashantha
(3,905 Views)
Hi Prashantha,
IVI class drivers will not work for a device that is not IVI compliant.  You may want to check your devices and make sure that they are IVI compliant.  For more information about IVI, please see the following link: IVI Foundation.
The IVI Custom Class Driver wizard provides instructions, but you can also look in the CVI help for more detailed information.  The CVI help is available online at the Online CVI 8.5 Help.  Please let me know if you are confused by a particular step and I can provide more information.
Please see the following KnowledgeBase Article, Building an IVI Driver Installer in LabWindows/CVI for more information about how to create an installer for your Custom IVI Driver.
Message Edited by J_Stape on 07-21-2008 11:18 AM
Jessica
Product Support Engineer
(3,866 Views)
Thansk for the valuable inputs , we are going through the documents suggested.
Regards
Prashantha
(3,844 Views)
Thanks for the valuable inputs , we are going through the documents suggested.
Regards
Prashantha
(3,843 Views)
