LabWindows/CVI
how to create a file with name give at run time?
hi,
the open/create file vi accepts file name as file path type and not a string,
i want to assign file name through a program,
please tell me how to do it,
if you can attach an example it will be halpful
thank you
akash
(2,817 Views)
Hi Akash,
you are wrong here, as you are asking a LabVIEW Question, you shoul post it in the LaBVIEW section, not in the CVI section. Take care the next time 😉
Anyway, here to your question:
Ther is a VI, that can "translate"  a string into the file path type. You can find it in the function palette:
Programming >>> File I/O >>> Adv File Funcs >>> string to path
Attached you can find an example, that uses a user defined prefix and the date to generate the path and filename dynamically.
Hope this helps!
André
(2,802 Views)
