LabWindows/CVI
how to create a phase indicator
hi everybody! i'm trying to create a phase indicator continuos 0-360 degrees. I found the numeric gauge indicato but it is not continuos. My targert is create an indicator as a compass.
Can you help me?
thanks
(4,070 Views)
Accepted by topic author DamBalzani
I don't understand your note as "non conuous", nevertheless I tried building up a compass indicator and ended up creating these two:
They are really multiple controls (two on the left and three for the right one) set one on top of the other and properly customized for range, orientation and colors.
I am attaching the .UIR file for your reference.
(4,032 Views)
thanks for your help.
My problem was that with numeric gauge i wasn't able to do a circolar indicator.
what is multiple control?
thanks for all
(4,022 Views)
As you can see in the .UIR, the left meter is really a gauge for the needle and a ring for the labels, the right one has two rings for the bold/plain labels. They are overlapped hiding or painting in transparent the unwanted elements.
(4,014 Views)
thanks for your help!!
(3,938 Views)
