LabWindows/CVI
how to delet a row or column in the table with labwindows
I want to delet any row or any column,how can I do it??
(4,138 Views)
Use DeleteTableRows and DeleteTableColumns to delete one or more rows or columns.  These functions take a 1-based row/column index, as well as the number or rows/coulmns you want to delete.  For example, if you just wanted to delete row 3 from your table, you would call:
DeleteTableRows(panelHandle, tableCtrl, 3, 1);
If you wanted to delete rows 3 and 4, you would call:
DeleteTableRows(panelHandle, tableCtrl, 3, 2);
Hope that helps.
Mert A.
(4,125 Views)
hehe,I know the function that you refered,but I want to know how to delet a row which select by the mouse in the table , i don't know how  to tell the funtion that which row or column has been selected.
(4,107 Views)
GetActiveTableCell returns the address of the active cell in a Point structure. See the help on this function for more details. To delete one row, basically you need only two functions:
 GetActiveTableCell (panel, control, &cell);
 DeleteTableRows (panel, control, cell.y, 1);
To delete multiple highlighted rows, you can use these functions:
 GetTableSelection (panel, control, &area);
 DeleteTableRows (panel, control, area.top, area.height);
(4,096 Views)
I'm sorry I misunderstood your previous post; a little more detail would have been helpful ;).
What you probably want to do is use the selected table cell range to determine which rows/columns to delete.  You can get the range of selected cells with the GetTableSelection function, then call the appropriate delete rows/columns function:
Rect selection;
GetTableSelection (panelHandle, tableCtrl, &selection);
if (selection.top > 0) /* there may not be any selected cells in the table */
    /* If you want to delete rows */
    DeleteTableRows (panelHandle, tableCtrl, selection.top, selection.height);
    /* If you want to delete columns */
    DeleteTableColumns (panelHandle, tableCtrl, selection.left, selection.width);
Hope this helps.
Mert A.
(4,093 Views)
