LabWindows/CVI
how to fix function redeclaration errors
I am using someone elses DLL and header file.  The header files defines a GetKey() function.  The CVI Utilities.h file also has a declaration of a GetKey() function.  How can I fix this issue.  I can not recompile the DLL to change the name.  I was thinking of  coping the utilitiy file locally and commenting out the GetKey() function so the software would compile.  Or is it possible to redefine a function?
Jon K.
(4,080 Views)
This [broken link removed; article no longer available] article offers some advice for a very similar scenario, which may be of help in your circumstances.
JR
(4,073 Views)
I could not get the #undef to work.  Where do I put it in C file or header file itself?
#include <Utilitity.h>
#undef GetKey
#incldue <xyz.h>
#include <mydll.h>
(4,068 Views)
as I've understand in the article,
you have two solutions :
first your code will include yourdll and then the utility.h from CVI
If it does not work, just add #undef function_name, it will undefine the CVI function
So it should be something like :
#include <yourdll>
#include <utility.h>
#undef GetKey()
(4,055 Views)
