LabWindows/CVI
how to generate multi-channel voltage at same time
I am a new Labwindows user,I need to use the onboard clock to update 4 voltage arrays in 4  different AO channels .After I Write all of my 4 voltage arrays into the buffer ,I find it can only generate one by one, more than starting at same time .Should I use two-dimensional array to save the 4 voltage arrays ,which will be write to the buffer by using this two-dimensional array rather then four one-dimensional arrays?Thank you for your help.
(4,803 Views)
Try to set the channel like this:"6229/ai0:3"
(4,791 Views)
I have set my channel like"Dev1/ao0:1",but when I write my voltage data into the buffer ,some error happen.The error info is like this "FATAL RUN-TIME ERROR:   "work.c", line 224, col 121, thread id 0x0000E838:   Array argument too small (4000000 bytes).  Argument must contain at least 8000000 bytes (1000000 elements)."
My board is NI6343,I use the DAQmxWriteAnalogF64 function ,the datalayout is interleaved.
(4,577 Views)
This question is related to this other thread where there can be a solution
(4,523 Views)
